Normal Topic Small issue of DiagramView scroll bar (Read 1711 times)
Kyle Chen
Aug 1st, 2013 at 2:26pm
Hi Stoyan,
For diagram view, I noticed if the scroll bar appears, it will cover section of diagram. I can't scroll to end of diagram bounds. Maybe the scroll range should count the width/height of scrollbar itself. Thanks.
Kyle
Re: Small issue of DiagramView scroll bar
Reply #1 - Aug 2nd, 2013 at 2:47pm
Are you sure your nodes are entirely within diagram.Bounds? This shows the node fully visible in my test project, even with scrollbars enabled:
diagram.AutoResize = AutoResize.None;
diagram.DefaultShape = Shapes.Rectangle;
diagram.ShadowsStyle = ShadowsStyle.None;
var rect = diagram.Bounds;
rect.Inflate(-1, -1);
diagram.Factory.CreateShapeNode(rect);
Kyle Chen
Reply #2 - Aug 2nd, 2013 at 8:13pm
You're correct Stoyan, again!
Thank you for your patience Cool
