Normal Topic Swim Lane Shape Placement (Read 4231 times)
jlj30
Aug 9th, 2013 at 12:13am
Have a look at the attached screenshot.
Can you tell me why the swim lane layout seems to place the shapes numbered 2.3, 2.4 and 2.5 in what I consider to be a desirable location, but 2.2 is placed to the extreme left of its swim lane.
Ideally, I'd like 2.2 vertically aligned with 2.3, but I was hoping the automatic layout would do that for me.
Any suggestions?
Jim
jlj30
Re: Swim Lane Shape Placement
Reply #1 - Aug 14th, 2013 at 1:47pm
Me again,
Any update on this?
I realize that I could force alignment myself in code (you provided me with a technique to do this just recently), but I'd like the swimLayout.Arrange(diagram) to do as much of this for me as possible.
I'd like to understand why the first shape placed in a lane is not necessarily positioned to the left of that lane.
Thanks in advance for any guidance.
Jim
Reply #2 - Aug 15th, 2013 at 5:44am
I am getting the following layout, check if you aren't moving the nodes later from some post-processing code.
diagram.EnableLanes = true;
diagram.LaneGrid.RowCount = 4;
var n00 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n00.LayoutTraits[SwimlaneLayoutTraits.Lane] = 0;
var n01 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n01.LayoutTraits[SwimlaneLayoutTraits.Lane] = 0;
var n10 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n10.LayoutTraits[SwimlaneLayoutTraits.Lane] = 1;
var n11 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n11.LayoutTraits[SwimlaneLayoutTraits.Lane] = 1;
var n12 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n12.LayoutTraits[SwimlaneLayoutTraits.Lane] = 1;
var n20 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n20.LayoutTraits[SwimlaneLayoutTraits.Lane] = 2;
var n21 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n21.LayoutTraits[SwimlaneLayoutTraits.Lane] = 2;
var n30 = diagram.Factory.CreateShapeNode(0, 0, 20, 15);
n30.LayoutTraits[SwimlaneLayoutTraits.Lane] = 3;
diagram.Factory.CreateDiagramLink(n10, n11);
diagram.Factory.CreateDiagramLink(n11, n12);
diagram.Factory.CreateDiagramLink(n12, n00);
diagram.Factory.CreateDiagramLink(n00, n01);
diagram.Factory.CreateDiagramLink(n11, n30);
diagram.Factory.CreateDiagramLink(n12, n20);
diagram.Factory.CreateDiagramLink(n20, n21);
var l = new SwimlaneLayout();
l.CompactNodes = true;
l.Arrange(diagram);
