Normal Topic ZoomToRect issue (Read 3509 times)
Kyle Chen
ZoomToRect issue
Aug 23rd, 2013 at 6:49pm
Hi Stoyan,
I met another issue in Zooming.
When I try to zoom the diagram view to a certain rectangle (union of some nodes bounds rectangle), the scrollbar will cover a portion of rectangle. It looks like the scrollbar area were not taken into account. I'm using the diagram 6.0.3.
See the screen shots and here's the code of "Zoom to Show All Nodes" button:
Code (C++)
        private void zoomToShowAllNodes_Click(object sender, EventArgs e)
            RectangleF rect = new RectangleF(0, 0, 0, 0);
            foreach (DiagramNode item in diagram1.Nodes)
                if (rect.IsEmpty)
                    rect = item.Bounds;
                else
                    rect = RectangleF.Union(rect, item.Bounds);
            diagramView1.ZoomToRect(rect);
Kyle
Re: ZoomToRect issue
Reply #1 - Aug 24th, 2013 at 10:22am
You can compensate for the scrollbars' area by multiplying ZoomFactor by the (view size - scrollbar) / (view size) ratio:
diagramView.ZoomToRect(rect);
diagramView.ZoomFactor *= Math.Min(
	1 - (float)diagramView.VScrollBar.Width / diagramView.Width,
	1 - (float)diagramView.HScrollBar.Height / diagramView.Height);
Kyle Chen
Reply #2 - Aug 28th, 2013 at 3:54pm
Thank you, it works perfect!
jf2020
I love FlowChart!
Reply #3 - Aug 31st, 2013 at 7:01am
If I may, I think that this should be taken into account automatically by the component. For the end user, the visible area is not the window including the scollbars, but only the area inside the scrollbars.
Similarly, it would be nicer if the horizontal scrollbar would extend to the far left and the vertical ruler would stop above the scrollbar.
Reply #4 - Sep 3rd, 2013 at 8:33am
Currently the scrollbars are child controls of DiagramView, and DiagramView is a child of Ruler, so they cannot stick out from the view to align with the ruler scales. However you could implement that by moving the scrollbars from the view to the parent form. E.g. assuming the form contains only a Ruler that fills it, this should align the scrollbars to that ruler:
private void Form1_Load(object sender, System.EventArgs e)
	diagramView.Controls.Remove(diagramView.HScrollBar);
	this.Controls.Add(diagramView.HScrollBar);
	diagramView.HScrollBar.Dock = DockStyle.Bottom;
	diagramView.Controls.Remove(diagramView.VScrollBar);
	this.Controls.Add(diagramView.VScrollBar);
	diagramView.VScrollBar.Dock = DockStyle.Right;
