Normal Topic DiagramLink drawing issue inside of a container (Read 1428 times)
j poz
Sep 10th, 2013 at 10:20pm
If a diagram link is connected from a shapenode inside of a container, routes outside of the container and then back into it to connect to another shapenode in that same container, the link will not be drawn outside of the container.
Re: DiagramLink drawing issue inside of a container
Reply #1 - Sep 11th, 2013 at 6:20am
This happens because of the new ClipChildren property of containers. Set it to false, and such links should be fully visible.
