Hot Topic (More than 10 Replies) IconNode's Text not Rendering Correctly (Read 7330 times)
SWATalk
Sep 12th, 2013 at 3:33am
Software version: 6.0.4
Diagram.DynamicLinks = true;
Diagram.MeasureUnit = Pixel;
I have created a custom node class (IconNode) based on the sample provided and the label property of the custom node does not render correctly. When the chart is small, the text does not appear but the link text does appear so it would appear there is a problem with how I am drawing the label for the IconNode. When I zoom in, the text property starts to appear but part of the top and bottom is cut off. As the diagram gets closer to 100%, the text is rendered correctly. I tried using labelBound.Inflate(5, 5) and then increased it to labelBound.inflate(100, 100) and that seem to work but the links aren’t rendered correctly at 100, 100. How can I resolve this issue?
My second issue involves laying out the custom nodes. If I use SpringLayout, it lays the nodes in one continuance line. When I change the layout to FractalLayout or TreeLayout (Radial), it displays the nodes correctly but the dynamic links do not work. I have also tried using FractalLayout with SpringLayout but that does not fix the dynamic links problem. Any ideas?
Custom Node class:
 [Serializable]
    public class IconNode : DiagramNode
        private Image m_Icon;
        private string m_Label;
        private StringFormat m_StringFormat;
        private static Image m_DefaultIcon;
        static IconNode()
            m_DefaultIcon = new Bitmap(48, 48);
            Graphics g = Graphics.FromImage(m_DefaultIcon);
            Font f = new Font("Segoe UI", 48, FontStyle.Bold, GraphicsUnit.Pixel);
            g.FillRectangle(Brushes.Transparent, 0, 0, 48, 48);
            g.DrawString("?", f, Brushes.Black, 0, 0);
            f.Dispose();
            g.Dispose();
        public IconNode(Diagram diagram)
            : base(diagram)
            m_Icon = m_DefaultIcon;
            m_Label = "Label";
            m_StringFormat = new StringFormat();
            m_StringFormat.Alignment = StringAlignment.Center;
            m_StringFormat.LineAlignment = StringAlignment.Center;
            Bounds = new RectangleF(Bounds.Location, CalculateSize());
        /// <summary>
        /// Gets or sets the image for the node.
        /// </summary>
        public Image Icon
            get { return m_Icon; }
            set
                m_Icon = value;
        /// <summary>
        /// Gets or sets the label for a node.
        /// </summary>
        public string Label
            get { return m_Label; }
            set
                m_Label = value;
        public override void DrawLocal(IGraphics graphics, RenderOptions options)
            Rectangle iconSizePixels = new Rectangle(0, 0, m_Icon.Width, m_Icon.Height);
            RectangleF imageSize = MindFusion.Utilities.DeviceToDoc(graphics, iconSizePixels);
            RectangleF localBounds = GetLocalBounds();
            // Draw the icon at the top-middle
            graphics.DrawImage(m_Icon, localBounds.X + localBounds.Width / 2 - imageSize.Width / 2, localBounds.Y);
            // Draw the label at the bottom
            RectangleF labelBounds = RectangleF.FromLTRB(localBounds.X, localBounds.Y + imageSize.Height, localBounds.Right, localBounds.Bottom);
            labelBounds.Inflate(10, 10);
            graphics.DrawString(m_Label, EffectiveFont, Brushes.Black, labelBounds, m_StringFormat);
        public override void DrawShadowLocal(IGraphics graphics, RenderOptions options) { }
        private SizeF CalculateSize()
            Bitmap tempImage = new Bitmap(1, 1);
            Graphics graphics = Graphics.FromImage(tempImage);
            IGraphics measureGraphics = new GdiGraphics(graphics);
            measureGraphics.PageUnit = Parent.MeasureUnit;
            RectangleF imageSize = MindFusion.Utilities.DeviceToDoc(measureGraphics, iconSizePixels);
            measureGraphics.Dispose();
            tempImage.Dispose();
            SizeF textSize = Parent.MeasureString(m_Label, EffectiveFont, int.MaxValue, m_StringFormat);
            return new SizeF(Math.Max(imageSize.Width, textSize.Width), imageSize.Height + textSize.Height);
        protected override void UpdateCreate(PointF current)
            base.UpdateCreate(current);
            Bounds = new RectangleF(current, CalculateSize());
        protected override void SaveTo(BinaryWriter writer, PersistContext ctx)
            base.SaveTo(writer, ctx);
            // Save the label using the standard .NET BinaryWriter
            writer.Write(m_Label);
            // Save the image using the MindFusion.Diagramming built-in image saving code,
            // which stores the contents of shared images only once.
            ctx.SaveImage(m_Icon);
        protected override void LoadFrom(BinaryReader reader, PersistContext ctx)
            base.LoadFrom(reader, ctx);
            m_Label = reader.ReadString();
            m_Icon = ctx.LoadImage();
Chart layout:
private void InitializeCustomNode()
            // Enable serialization of IconNode instances
            if ((diagram as IItemFactory).TypeTable[typeof(IconNode)] == null)
                Diagram.RegisterItemClass(typeof(IconNode), "IconNode", 1);
            // Let users draw IconNode objects
            diagramView.CustomNodeType = typeof(IconNode);
            //diagramView.Behavior = Behavior.Custom;
private void InitializeLinkChart()
            LinkChartService service = new LinkChartService();
            m_Entities = service.GetAllEdges();
            diagramView.AutoScroll = true;
            diagram.ShowGrid = false;
            diagramView.ShowScrollbars = true;
            // Changes the active item's handlestyle by showing a border when a node is selected.
            diagram.ActiveItemHandlesStyle.DashPen = new MindFusion.Drawing.Pen(Color.Blue);
            diagramView.SmoothingMode = SmoothingMode.AntiAlias;
            PopulateNodes();
            /*using (TreeLayout layout = new TreeLayout(TreeLayoutType.Radial))
                layout.NodeDistance = 150;
                layout.Arrange(diagram);
            using (FractalLayout layout = new FractalLayout())
                layout.Anchoring = Anchoring.Reassign;
            using (SpringLayout slayout = new SpringLayout(500, 200, true))
                //slayout.BeginArrange(diagram, diagram.Items);
                slayout.EnableClusters = true;
                slayout.Arrange(diagram);
                //slayout.EndArrange();
            diagram.AutoResize = AutoResize.AllDirections;
            diagram.ResizeToFitItems(diagram.Nodes.Count);
            diagramView.ZoomFactor = 50;
private void PopulateNodes()
            foreach (DataRow row in m_Entities.Rows)
                //CreateNode((int)row["FromNodeId"], row["FromNode"].ToString());
                //CreateNode((int)row["ToNodeId"], row["ToNode"].ToString());
                //ConnectNodes((ShapeNode)diagram.FindNodeById((int)row["FromNodeId"]), (ShapeNode)diagram.FindNodeById((int)row["ToNodeId"]), row["RelationshipType"].ToString());
                CreateIconNode((int)row["FromNodeId"], row["FromNode"].ToString());
                CreateIconNode((int)row["ToNodeId"], row["ToNode"].ToString());
                ConnectIconNodes((IconNode)diagram.FindNodeById((int)row["FromNodeId"]), (IconNode)diagram.FindNodeById((int)row["ToNodeId"]), row["RelationshipType"].ToString());
private void CreateIconNode(int key, string value)
            if (diagram.FindNodeById(key) != null)
                return;
            IconNode iconNode = new IconNode(diagram);
            iconNode.Id = key;
            iconNode.Label = value;
            iconNode.Icon = Properties.Resources.UserBlue48;
            iconNode.HandlesStyle = HandlesStyle.MoveOnly;
            diagram.Nodes.Add(iconNode);
private void ConnectIconNodes(IconNode parent, IconNode child, string label)
            if (child == null)
                return;
            DiagramLink link = diagram.Factory.CreateDiagramLink(parent, child);
            link.Text = label;
            link.TextStyle = LinkTextStyle.OverLongestSegment;
            link.Font = new System.Drawing.Font("Segoe UI", 9.0f);
Re: IconNode's Text not Rendering Correctly
Reply #1 - Sep 12th, 2013 at 10:50am
DeviceToDoc will not give you the correct document size of the image when there is ZoomFactor set; it expects size in pixels that corresponds to the zoom level, but you pass to it unscaled image size in pixels. Change ImageSize to following if you need to support multiple MeasureUnits:
imageSize.Width *= options.Scale / 100;
imageSize.Height *= options.Scale / 100;
If using only pixels as unit, you do not need any conversion, and could just set Rectangle imageSize = iconSizePixels;
Try running SpringLayout with Randomize set to true if you start with all nodes at the same position.
SWATalk
Reply #2 - Sep 12th, 2013 at 3:28pm
Spot on...problem solved.  Thanks Stoyo
SWATalk
Reply #3 - Oct 2nd, 2013 at 2:39am
Back to square one.  This code actually does not work on a monitor with a resolution of 1920x1080.  In addition, when you view it by clicking print preview, all of the nodes are bunched together and does not look like anything that appears on the original diagram.
Any thoughts?
Reply #4 - Oct 2nd, 2013 at 8:32am
It works fine in our test on 1920x1080, see attached screenshot. It shows IconNodes with unit set to Pixel, your version of the class and the scaling fix above applied. Have you changed anything else in the drawing code or properties from IconNodes?
When you use Pixel as unit, one unit corresponds to a device pixel. The nodes get bunched together because the printer pixels are much smaller. If you want to print with Pixel unit and get similar resolution as on screen, you will have to either apply additional scale in PrintOptions, or print a copy of the diagram where Unit is switched to Point (or WpfPoint = 96 dpi from version 6.1).
SWATalk
Reply #5 - Oct 2nd, 2013 at 5:40pm
Unfortunately that does not work for me. This is what it looks like on my screen:
SWATalk
Reply #6 - Oct 2nd, 2013 at 5:43pm
Print preview code:
public static double ScreenDPI(int monitorSize, int resolutionWidth, int resolutionHeight)
            //int resolutionWidth = 1600;
            //int resolutionHeight = 1200;
            //int monitorSize = 19;
            if (0 < monitorSize)
                double screenDpi = Math.Sqrt(Math.Pow(resolutionWidth, 2) + Math.Pow(resolutionHeight, 2)) / monitorSize;
                return screenDpi;
            return 0;
Print preview code
diagramView.PrintOptions.HeaderFormat = "Diagram Title";
                    var screenResolution = ScreenDPI(24, 1920, 1080);
                    var printerResolution = 72f; // for Point unit
                    var newDiagramView = new DiagramView();
                    diagramView.Diagram.LoadFromString(diagram.SaveToString()); // copy the main diagram
                    diagramView.Diagram.MeasureUnit = GraphicsUnit.Point;
                    diagramView.PrintOptions.Scale = 100f * (float)(screenResolution / printerResolution);
                    // ****** Somewhat works ******
                    //diagram.MeasureUnit = GraphicsUnit.Point;
                    //diagramView.PrintOptions.Scale = 72;
                    //diagramView.PrintOptions.ScaleToPage();
                    //PrintDocument doc = new PrintDocument();
                    //diagramView.PrintOptions.Scale = doc.PrinterSettings.DefaultPageSettings.PrinterResolution.X;
                    diagramView.PrintPreviewEx();
When I click print preview and return to the diagram, the diagram looks like the print preview.  I don't think that's how it is supposed to function.
SWATalk
Reply #7 - Oct 2nd, 2013 at 6:43pm
I am drawing a border around the image and the question mark and this is what it looks like.  The border is drawn correctly but the "?" and the icon is not.  Any ideas?
SWATalk
Reply #8 - Oct 2nd, 2013 at 6:46pm
This is the icon node and it is 48x48 and centered.
Reply #9 - Oct 3rd, 2013 at 7:34am
SWATalk wrote on Oct 2nd, 2013 at 5:40pm:
This has nothing to do with your initial zoom problem.
The question mark is cut off because the bold 48px Segoe UI question mark symbol does not fit within the 48x48 bitmap when drawn aligned to top left corner. I suppose the actual glyph drawing starts around the 6th-7th scanline and then there's no place for the bottom part of the base point. It seems to fit ok if you draw it centered:
static IconNode()
	g.DrawString("?", f, Brushes.Black, 24, 24, new StringFormat
		Alignment = StringAlignment.Center,
	f.Dispose();
	g.Dispose();
Quote:
The label is above the image but there should be a space ...
The labelBounds rectangle overlaps the icon rectangle after you call Inflate.
// at this point labelBounds starts exactly below the image
// now labelBounds starts 10 pixels above its old coordinates and overlaps the image
If you need to draw in a larger rectangle, make sure its Y starts below the icon's bottom line to avoid that overlap.
Reply #10 - Oct 3rd, 2013 at 7:49am
SWATalk wrote on Oct 2nd, 2013 at 5:43pm:
Print preview code:
                return screenDpi;
            return 0;
Print preview code
If you are changing MeasureUnit on the original diagram, you should restore it back to Pixel after calling PrintPreview. Or alternatively, print a copy of the diagram to prevent users from seeing the on-screen diagram changed (e.g. if the print preview window is not maximized).
var copyForPrint = new Diagram();
copyForPrint.LoadFromString(diagram.SaveToString());
copyForPrint.MeasureUnit = GraphicUnit.Point;
var printView = new DagramView();
printView.Diagram = copyForPrint;
printView.PrintPreviewEx();
Reply #11 - Oct 3rd, 2013 at 8:02am
SWATalk wrote on Oct 2nd, 2013 at 6:43pm:
graphics.DrawImage(x, y) might be stretching the image a bit if its DPI is different than the screen's DPI. Try using the DrawImage(rect) overload instead:
var iconRect = new RectangleF(
	localBounds.Y, imageSize.Width, imageSize.Height);
graphics.DrawImage(m_Icon, iconRect);
graphics.DrawRectangle(Pens.Red, iconRect);
or try calling bitmap.SetResolution(graphics.DpiX, graphics.DpiY) before drawing with the (x,y) overload.
SWATalk
Reply #12 - Oct 4th, 2013 at 1:20am
Stoyo,
Your suggestions seemed to work, however, when I click print preview, the icons are really tiny.  Any ideas on a fix?
Reply #13 - Oct 4th, 2013 at 6:31am
The unit conversion in Draw actually gives you a size corresponding to 48 printer pixels; it seems to work fine if you remove it, both on printer and when zooming on the screen:
//Rectangle iconSizePixels = new Rectangle(0, 0, m_Icon.Width, m_Icon.Height);
//RectangleF imageSize = MindFusion.Utilities.DeviceToDoc(graphics, iconSizePixels);
// now that's in device-independent points when printing
RectangleF imageSize = new Rectangle(0, 0, m_Icon.Width, m_Icon.Height);
