Normal Topic Can shapenode be converted to SVGNode? (Read 1608 times)
irix
Sep 13th, 2013 at 11:34am
Hello, we used shapenodes in our  application, and now we prepare to use svgnode to display svg images. But we find a new problem: the old serialized xml file is for shapenode, so when deserialized can shapenode be converted to SVGNode?
Re: Can shapenode be converted to SVGNode?
Reply #1 - Sep 13th, 2013 at 12:20pm
You could modify the XML document at runtime to change the node types, and then set the Content of SvgNodes after loading:
var doc = new XmlDocument();
doc.Load(file_path);
var nodeElements = doc.SelectNodes(@"/Diagram/Nodes/Node");
if (nodeElements != null)
	foreach (XmlElement element in nodeElements)
		if (element.Attributes["Class"].Value == "std:ShapeNode")
			element.Attributes["Class"].Value = "std:SvgNode";
diagram.LoadFromXml(doc);
foreach (var node in diagram.Nodes)
	var svgNode = node as SvgNode;
	if (svgNode != null & svgNode.Content == null)
		svgNode.Content = ...;
irix
Reply #2 - Sep 14th, 2013 at 1:46pm
thanks very much,  Smiley
