Normal Topic Terminate early during long operations like RouteAllArrows and FindAllPaths (Read 5404 times)
bt1
Sep 17th, 2013 at 11:07am
I am working with large interactive graphs and most operations like FindAllPaths, RouteAllArrows and ArrangeDiagram can take a long time to run (especially RouteAllArrows).
I do all graph operations in background threads so the rest of my GUI remains responsive and this is working nicely.
I need to be able to gracefully terminate background threads on demand. Calling kernel32!TerminateThread is not a solution as I need clean-up code and other things to execute when the thread is finishing up.
For all my non-graph background threads I can test if the current thread has been signalled to terminate and if so then stop the current operation early. I cant seem to do this with a FlowChartX control.
How do I signal long operations (FindAllPaths, RouteAllArrows and ArrangeDiagram) to finish early? is there a variable I can set to force a FlowChart component to finish its current operation early, or is there a callback I can use?
Thanks.
Re: Terminate early during long operations like RouteAllArrows and FindAllPaths
Reply #1 - Sep 17th, 2013 at 12:59pm
RouteAllArrows just loops over all arrows and calls their Route method. So you could implement your own for-each loop that calls arrow.Route and breaks if some bool variable is set.
You could do something similar for ArrangeDiagram if using force-directed algorithms (spring, anneal, grid, circular layouts). E.g. run only a few iterations inside the loop, break if a variable is set, otherwise continue with more iterations.
bt1
Reply #2 - Sep 17th, 2013 at 2:05pm
Thanks, implementing a simple RouteAllArrows method which checks for early termination is working perfectly.
I can get by without early termination for FindAllPaths and ArrangeDiagram for now, although perhaps this could be a feature in a future version.
Thank you very much for your help Smiley
