Normal Topic Custom link drawing mode, a question... (Read 1948 times)
j poz
Sep 19th, 2013 at 3:42pm
Is there a way to override the custom draw behavior of a link, but in some cases, rely on the default drawing behavior? That is, setting LinkCustomDraw to CustomDraw.Full, but then calling a base function somewhere to draw the link as it would normally appear?
Re: Custom link drawing mode, a question...
Reply #1 - Sep 19th, 2013 at 5:45pm
You can set the CustomDraw property of individual links. If you cannot decide whether a link should be custom drawn until the event is raised, you can draw its segments easily by calling the DrawLines or DrawBeziers method of e.Graphics with ControlPoints.GetArray() as argument, and calling link.DrawArrowhead to draw the arrowhead shapes. That won't work if you use the LinkCrossings property though.
Alternatively, your DrawLink handler could do something like this to run the standard drawing code:
e.Link.CustomDraw = None;
e.Link.Draw(e.Graphics, new RenderOptions());
e.Link.CustomDraw = Full;
