Normal Topic Install licenced Version after testing the trial version (Read 1988 times)
Oli
Sep 23rd, 2013 at 8:57am
Hello
I made some tests with the trial version and bought now a full version. In the downloaded zip-file was no readMe.txt or advice how to install.
Do I have anything to consider, like uninstall first the trial version to get no conflicts?
Thanks for every note.
Re: Install licenced Version after testing the trial version
Reply #1 - Sep 23rd, 2013 at 9:22am
The installer does not copy anything to the GAC or other shared locations, and it should be enough to update your project's reference path to point to the new installation path. Also make sure the references' Use Specific Version property is set to false, or VS might keep using the demo assemblies from the project's bin folder. Better uninstall the demo version anyway to avoid any possibility of conflicts.
