Normal Topic diagramViewer.NodeClicked Event fires only on left mouse button (Read 7229 times)
Oli
Sep 27th, 2013 at 11:05am
Hello
I have a layeredLayout Diagram in an ASP.net page.
(.NET 4.5, Browser IE 9)
In each node shall be a right-click context-menu available.
The values in the context-menu are depending on the node values.
I tried the following:
In the aspx-page I set <body onmousedown="return false;">
In code-behind I did
Private Sub diagramViewer_NodeClicked(sender As Object, e As MindFusion.Diagramming.NodeEventArgs) Handles diagramViewer.NodeClicked
If (e.MouseButton <> MouseButton.Left) Then
Dim nodeTag As String = e.Node.Tag
Dim x As Single = e.Node.Bounds.X
Dim y As Single = e.Node.Bounds.Y...
and so on.
My problem is that the "NodeClicked" event fires only on left mouse clicks, never on a right click.
Any idea what I'm doing wrong or is there even a better way to get a context-menu?
Thanks in advance!
Oli
Re: diagramViewer.NodeClicked Event fires only on left mouse button
Reply #1 - Sep 27th, 2013 at 11:10am
See http://mindfusion.eu/Forum/YaBB.pl?num=1343319764/1#1 for a context menu example.
Oli
Reply #2 - Sep 28th, 2013 at 10:14am
Hello Stoyan
thank you for your help.
I got the thing working, but it does not realy solve my problem ( or I didn't see it all). I need a node-specific context-menu and therefore it is essential that I know which node was clicked.
I was thinking of scenarios like:
  • Javascript reads the node-value and stores the value in a hiddenfield. After that I can start my serverside code which writes the specific context-menu for the clicked node and displays it.
  • call from the mousedown event handler which was added before as Attribute (like described in your post) a serverside function, which writes the specific context-menu for the clicked node and displays it.
Is one of these two scenarios possible or do you have a third, better idea ( I would appreciate that)
Thank you in advance!
Oli
Reply #3 - Sep 30th, 2013 at 6:21am
Hi Oli,
In CreatingAreaElement event handler the current node is accessible via the args.Item property. If you identify nodes by their Tag or Id values, you could append args.Item.Tag/Id as argument to the onNodeMouseDown JS function, and then show a node-specific menu depending on the id parameter value.
Oli
Reply #4 - Sep 30th, 2013 at 7:16am
HI Stoyan
I tried your advice and added in the CreatingAreaElement event Handler the following:
e.Attributes("onmousedown") = "return onNodeMouseDown(event, event.item.Id)"
But there pops up a JS error - Id is undefined or nothing.
I 'm sorry but I'm really a lame duck in JS...
Thanks for any help.
Oli
Reply #5 - Sep 30th, 2013 at 7:46am
I meant you should append the Id value to the attribute string to generate item-specific scripts:
e.Attributes["onmousedown"] = "return onNodeMouseDown(event," + e.Item.Id + ")";
And also add a second Id parameter to onNodeMouseDown, which will receive the Id value set from the server.
Oli
Reply #6 - Sep 30th, 2013 at 7:57am
Hi Stoyan
Great, it works, thanks a lot for this excellent support! Cool
Oli
