Normal Topic Placing image before caption (Read 2721 times)
Kiran B
Oct 2nd, 2013 at 7:59pm
How can i place an image in a shape/container node just before caption?
I need an image before caption as shown in the image of below post.
http://mindfusion.eu/Forum/YaBB.pl?num=1378969922
Attaching the image for reference.
I tried the below approach but its hiding the caption
http://mindfusion.eu/Forum/YaBB.pl?num=1367227880/1#1
Re: Placing image before caption
Reply #1 - Oct 3rd, 2013 at 12:54pm
The nodes in that post are ShapeNodes, and the icon, caption and divider line there are part of the image assigned to ShapeNode.ImageUrl - the same image whose copy you have attached above.
The CustomNodes sample project shows how to draw additional labels and images in a node without putting everything in a bitmap.
Kiran B
Reply #2 - Oct 23rd, 2013 at 7:14pm
Which is the CustomNodes sample project you are referring?
Could you please provide me the link?
Kiran B
Reply #3 - Oct 24th, 2013 at 3:12pm
You can find it in \Samples\CSharp\CustomNodes subfolder under the MvcDiagram root installation folder.
