Normal Topic Container with rounded corners (Read 4430 times)
Kiran B
Oct 21st, 2013 at 8:02pm
How can i make container nodes with rounded corners.
Kiran B
Re: Container with rounded corners
Reply #1 - Oct 22nd, 2013 at 12:43pm
You would use the ContainerNode.Shape property, but we haven't implemented it yet in JavaScript. For the time being you could custom-draw the rounded rectangle:
container.onUpdateVisuals = onUpdateVisuals;
function onUpdateVisuals(node)
    var shape = MindFusion.Diagramming.Shape.fromId('RoundRect');
    var path = new MindFusion.Drawing.Path(shape.params.outline);
    var shapeBounds = shape.defaultBounds;
    var bounds = node.getBounds();
    var x = bounds.width / shapeBounds.width;
    var y = bounds.height / shapeBounds.height;
    var matrix = new MindFusion.Drawing.Matrix();
    matrix.translate(bounds.x - bounds.width / 2, bounds.y - bounds.height / 2);
    matrix.scale(x, y);
    matrix.translate(
        bounds.width / x - shapeBounds.x - shapeBounds.width / 2,
        bounds.height / y - shapeBounds.y - shapeBounds.height / 2);
    path.transform = matrix;
    node.graphicsContainer.content.splice(0, 1, path);
Kiran B
Reply #2 - Oct 23rd, 2013 at 5:55pm
Hi Stoyan,
Its working , but few issues.
The background color i have given for container is getting lost when i use the above code.
Also the caption title is getting overlapped with the rounded corners when i enlarge the container.
Also is there any way to apply this globally to all containers?
The code i have used is
diagram.items[0].onUpdateVisuals = onUpdateVisuals;
Kiran B
Reply #3 - Oct 24th, 2013 at 8:54am
Try this
var ContainerNode = MindFusion.Diagramming.ContainerNode;
var originalDraw = ContainerNode.prototype.updateCanvasElements;
ContainerNode.prototype.updateCanvasElements = function ()
	originalDraw.apply(this);
	var w = this.bounds.width;
	var h = this.bounds.height;
	var r = 3;
	var pathString = String.format(
		'M0,{2} L0,{4} Q0,{1},{2},{1} L{3},{1} Q{0},{1},{0},{4} L{0},{2} Q{0},0,{3},0 L{2},0 Q0,0,0,{2} Z',
		w, h, r, w - r, h - r);
	var path = new MindFusion.Drawing.Path(pathString);
	path.brush = this.brush;
	path.transform.translate(this.bounds.x, this.bounds.y);
	this.graphicsContainer.content.splice(0, 1, path);
Kiran B
Reply #4 - Oct 24th, 2013 at 4:41pm
Hi Stoyan,
Working perfectly.
Kiran B
