Normal Topic How to get a flipped contaienr with correct bounds? (Read 1475 times)
Homam
Oct 8th, 2013 at 7:49am
I needed to build a horizontal container as the attached image. I found an easy way is to flip the built-in container that you provided using the following code:
Code (C++)
// On creating the container,
container.RotationAngle = -90;
container.Resize(200, 400);
container.Move(location.X + 100, location.Y - 100);
The problem is that when I get the bounds of this container, the diagram is giving the original bound not the flipped ones.
Any suggestion?
Re: How to get a flipped contaienr with correct bounds?
Reply #1 - Oct 8th, 2013 at 9:17am
Instead of Bounds, call container.GetRotatedBounds().
