Normal Topic How can I draw the rectangle like Border to all nodes and links in the diagram. (Read 7121 times)
Todkar
Oct 10th, 2013 at 12:23pm
I have one container shape and inside that have multiple Nodes and their link.
I want to resize and set bounds to container Node base on all nodes / Links bounds.
please refer the attached image;
How can I achieve this?
Re: How can I draw the rectangle like Border to all nodes and links in the diagram.
Reply #1 - Oct 11th, 2013 at 6:19am
If that container will contain all diagram items, call diagram.GetContentBounds before creating it and set container.Bounds to the returned content rectangle.
Todkar
Reply #2 - Oct 11th, 2013 at 9:03am
thanks for your reply,
I will try your suggestion
one question
see the attached image; Is it possible to get Highlighted points from the diagram? [Min and Max point of node / link utilized in the diagram; so that we draw rectangle based on that]
Reply #3 - Oct 11th, 2013 at 9:52am
The DiagramItem.GetBounds() method returns a Rect that contains all control points for DiagramLinks or the node's bounding rectangle for DiagramNodes. You could loop over all items to collect min/max coordinates or call Rect.Union() to find the union of all items' rectangles returned by GetBounds(). You can get individual control points of links using their ControlPoints property.
