Normal Topic How to set ContainerNode border? (Read 3093 times)
EricHu
Oct 11th, 2013 at 11:26am
Three questions about ContainerNode:
1 Can caption text alignment be set?
2 Can caption brush be set separately?
3 How to set border style?
and another question:
Can mouse cursor be set hand when diagram behavior set 'Behavior.DoNothing',because need raise click node or link event.
Expecting your answer.
Re: How to set ContainerNode border?
Reply #1 - Oct 11th, 2013 at 12:00pm
1 and 2 are not available out of the box. You could use the onUpdateVisuals custom-draw callback to implement them:
var Alignment = MindFusion.Diagramming.Alignment;
container.onUpdateVisuals = onUpdateVisuals;
function onUpdateVisuals(node)
	node.text.textAlignment = Alignment.Center;
	var captionBar = node.getBounds().clone();
	captionBar.height = node.captionHeight;
	captionBar.brush = "red";
	node.graphicsContainer.content.splice(1, 0, captionBar);
You can use the setStroke and setStrokeThickness functions of DiagramItem to customize the border.
EricHu
Reply #2 - Oct 12th, 2013 at 1:35am
It works well,thank you very much.
But i can not find 'onUpdateVisuals ' in Online Documentation.Smiley
Reply #3 - Oct 12th, 2013 at 6:50am
It's a well-guarded secret Smiley I think our developer added it to let someone add extra icons to nodes, and forgot to document it after that. You can find several examples in the ASP.NET MVC and JavaScript forum boards if you are interested in custom-drawing.
