Normal Topic Odd tooltip displayed (Read 4066 times)
Oli
Oct 11th, 2013 at 1:40pm
I have a layered layout diagram running.
I create nodes for the diagram in code behind.
While creating the nodes, the tooltip is set with the following code:
node.ToolTip = "click to open details to this dataset"
The weird thing is, that this tooltip is only displayed in JavaApplet, in ImgageMap the tooltip looks like shown in the attachement.
Does anybody know what I'm doing wrong?
Oli
Re: Odd tooltip displayed
Reply #1 - Oct 11th, 2013 at 2:05pm
The control assigns Tooltip to the AREA's Title attribute, and that string identifier to the Alt attribute. The five browsers we test with show the tooltip (Title attribute) correctly, in what browser are you seeing the Alt value?
Oli
Reply #2 - Oct 11th, 2013 at 2:15pm
Hello Stoyan
thanks for your fast reply!
I'm running this application in IE9.
I'm quite shure that this problem was not there all the time...
What I did on your advice was switching the DLLs to version 5.0.1 because of the Java Warning, but I tried the issue with the "old" DLLs and the tooltip problem was still there.
The other change was, that yesterday have been windows updates loaded but only for .NET 3.5 not .Net 4.0 (where my application runs)?
additional: I tested the issue in Firefox and there the tooltip is displayed like expected
Oli
Reply #3 - Oct 11th, 2013 at 4:52pm
Hi Oli,
We've tried it with IE9 too but the tooltip displays fine. Can you see the correct title value if you look in the generated html code in IE? Also can you see any differences if you save the pages from Firefox and IE and compare them with windiff?
Oli
Reply #4 - Oct 14th, 2013 at 6:09am
Hi Stoyan
Yesterday I started to analyze the differences, like you told me. I started the two Browsers (IE9 and Firefox) and both displayed the same, right tooltip!? If I hadn't done a screenshot I thought I'm completly crazy. So I checked again what happened to my system between this two tests.
There was a windows-defender definition update (see screenshot below). So it looks like this update has fixed the problem (and one of the ones before caused the trouble...).
I'm sorry that I created additional work for you and thank you for your help.
Oli
Reply #5 - Oct 14th, 2013 at 6:40am
Hi Oli,
Actually we were able to reproduce that by turning on IE's compatibility mode. We'll see if we can do anything about it.
Oli
Reply #6 - Oct 14th, 2013 at 7:16am
Hello Stoyan
you are right and I was wrong, switching in compatibility mode of IE 9 brings the problem back.
Please let me know when you have found a solution.
Thanks.
Oli
