Normal Topic WPF vs. WinForms (Read 2271 times)
Vincent
WPF vs. WinForms
Oct 15th, 2013 at 2:21pm
Hi Stoyan,
I've got 3 questions about the differences between MindFusion for WPF and WinForms.
Question 1:
In WPF I can override the Draw method of a custome-made node with the following code:
 public override void Draw(DrawingContext graphics, MindFusion.Diagramming.Wpf.RenderOptions options)
            double totalHeight = Bounds.Height;
            double padding = 20;
            double ifHeight = Then_connected_node != null ? Then_connected_node.Bounds.Height : 0;
            double elseHeight = Else_connected_node != null ? Else_connected_node.Bounds.Height : 0;
            // Then-part and Else-part are null
            if (ifHeight == 0 && elseHeight == 0)
                ifHeight = elseHeight = (totalHeight - 3 * padding) / 2;
            // Only Then-part is null
            else if (ifHeight == 0)
                ifHeight = totalHeight - elseHeight - 3 * padding;
            // Only Else-part is null
            else if (elseHeight == 0)
                elseHeight = totalHeight - ifHeight - 3 * padding;
            var shape = new PathGeometry();
            shape.Figures.Add(new PathFigure(new Point(), new[]
                new LineSegment(new Point(5, 0), true),
                new LineSegment(new Point(10, -7), true),
                new LineSegment(new Point(15, 0), true),
			    new LineSegment(new Point(Bounds.Width, 0), true),
			    new LineSegment(new Point(Bounds.Width, padding), true),
                new LineSegment(new Point(35, padding), true),
                new LineSegment(new Point(30, padding-7), true),
                new LineSegment(new Point(25, padding), true),
			    new LineSegment(new Point(padding, padding), true),
			    new LineSegment(new Point(padding, padding + ifHeight), true),
			    new LineSegment(new Point(Bounds.Width, padding + ifHeight), true),
			    new LineSegment(new Point(Bounds.Width, Bounds.Height - padding - elseHeight), true),
                new LineSegment(new Point(35, Bounds.Height - padding - elseHeight), true),
                new LineSegment(new Point(30, Bounds.Height - padding - elseHeight - 7), true),
                new LineSegment(new Point(25, Bounds.Height - padding - elseHeight), true),
			    new LineSegment(new Point(padding, Bounds.Height - padding - elseHeight), true),
			    new LineSegment(new Point(padding, Bounds.Height - padding), true),
			    new LineSegment(new Point(Bounds.Width, Bounds.Height - padding), true),
			    new LineSegment(new Point(Bounds.Width, Bounds.Height), true),
                new LineSegment(new Point(15, Bounds.Height), true),
                new LineSegment(new Point(10, Bounds.Height-7), true),
                new LineSegment(new Point(5, Bounds.Height), true),
			    new LineSegment(new Point(0, Bounds.Height), true),
			    new LineSegment(new Point(0, 0), true),
		    }, true));
            graphics.DrawGeometry(Brush, new Pen(Stroke, StrokeThickness), shape);
Is it possible to achieve the exact same in WinForms? I tried to paste the same code in a WinForms project but it doesn't seem to recognize the PathGeometry class.
Question 2:
In WPF there is a property in the Diagram class called ModificationEffect. If I set this property to ModificationEffect.MoveShades I would get a preview when moving a node in the diagram. Is there a similar property in WinForms?
Question 3:
With the code below I can drag and drop Nodes to a Diagramfield from a NodeListView and while I do this I get a preview under my cursor. Is this possible with WinForms as well ?
    private DiagramNode dragIndicator = null;
        public InteractionState dragInteraction = null;
        // The three functions OnDiagramDragEnter, OnDiagramDragOver, OnNodeCreatedmethode are used
        // to be able to have a dragpreview.
        // This method is called when the cursor enters the corresponding window
        private void OnDiagramDragEnter(object sender, DragEventArgs e)
            // The if statement checks if dragIndicator is empty and if there is a dragNode present
            if (dragIndicator == null && e.Data.GetDataPresent(typeof(DraggedNode)))
                this.ModificationEffect = ModificationEffect.None;
                // var data gets present node that is dragable
                // var position gets the current position of the node that can be dragged
                var data = (DraggedNode)e.Data.GetData(typeof(DraggedNode));
                var position = e.GetPosition(this.DocumentPlane);
                // Make a Copy of the current node, its on 'false' cause its not getting use by the clipboard
                dragIndicator = (DiagramNode)data.Node.Clone(false);
                dragIndicator.Move(position.X, position.Y); // Keeps track of the position
                dragInteraction = new InteractionState(dragIndicator, 8, MindFusion.Diagramming.Wpf.Action.Modify);
                dragInteraction.Start(position, this);
                dragIndicator.Opacity = 0.5; // Changes the opacity of the node so that it looks transparent
                this.Nodes.Add(dragIndicator); // Node is being added to the diagram - this = the diagram
                e.Effects = DragDropEffects.Copy;
                e.Handled = true;
        // This method is called when the cursor moves inside the cursor moves inside the corresponding window
        public void OnDiagramDragOver(object sender, DragEventArgs e)
            // Checks whether the dragindicator is filled with the data of the node that is being dragged
            if (dragIndicator != null)
                dragInteraction.Update(position, this);
                //dragIndicator.Move(position.X, position.Y);
                e.Handled = true;
        // Removes the contents of the dragIndicator, so it can be use again if
        private void OnNodeCreated(object sender, NodeEventArgs e)
                this.ModificationEffect = ModificationEffect.MoveShades;
                e.Node.Bounds = dragIndicator.Bounds;
                this.Nodes.Remove(dragIndicator);
                BR_Shape.lastInflatedNode = null;
Greets,
Vincent
Re: WPF vs. WinForms
Reply #1 - Oct 15th, 2013 at 4:29pm
Hi Vincent,
1. With Windows Forms control it is better to override the DrawLocal method. You will have to use the GDI+ API to draw graphics primitives instead of WPF classes. In this case, create a GraphicsPath object, and call the FillPath and DrawPath methods of the Graphics class.
2. ModificationEffect is not available in Windows Forms.
3. The WinForms version of NodeListView draws such preview shape automatically while dragging.
Vincent
Reply #2 - Oct 18th, 2013 at 11:09am
Ah ok, thanks!!  Smiley
Greets,
Vincent
