Normal Topic Reframing the diagram based on user's node addition/deletion (Read 4319 times)
Chris B.
Oct 16th, 2013 at 3:16am
Hi MindFusion!
      Is there a way for us to reframe the diagram after a user deletes (or adds) a node?
      There are a lot of unnecessary white spaces left out especially after a user deletes a node that was placed at a very far distant from the rest of the nodes in some corner of the diagram. Deleting that node makes the effective area of the diagram much smaller if we exclude the whitespaces.
      Our objective is to reframe the diagram to remove white spaces so that the outermost nodes almost touch the edge of the diagram. Can we do that at the client-side script? We would like to avoid rearranging the layout since we want to keep position of existing nodes intact.
Re: Reframing the diagram based on user's node addition/deletion
Reply #1 - Oct 16th, 2013 at 6:07am
Call diagram.resizeToFitItems() from the NodeDeleted event handler.
Chris B.
Reply #2 - Oct 28th, 2013 at 7:40am
Hi Stoyo,
       diagram.resizeToFitItems() works beautifully on the diagram. However, there seems to be an issue with reflecting the same changes on the overview after calling resizeToFitItems().
        Unnecessary whitespace created by deletion of a node in that area has been removed nicely in the diagram while in the overview, it still remains. However, overview seems to notice width and height change of the diagram and it changes its width and height accordingly, creating a cropped representation inside overview.
        The issue only occurs if nodes are deleted one by one from left to right or top to bottom. If we delete nodes from right to left or bottom to top, there is no issue because the whitespace is automatically removed by reduced width and height.
Reply #3 - Oct 28th, 2013 at 9:02am
Have you moved to the released 1.6 version? In older versions the Overview did not work correctly with non-zero diagram.Bounds origin.
Chris B.
Reply #4 - Oct 29th, 2013 at 1:39am
Hi Stoyo,
      By version 1.6, you meant the one you sent via PM that uses canvas for drawing overview? If it is the one, we are using that version. We confirm that the issue is still there with that version.
Reply #5 - Oct 29th, 2013 at 6:32am
Hi Chris,
What I sent you was a pre-release build to fix the overview's tracker rectangle if I recall correctly. We released version 1.6 later and it should contain some more Overview fixes (http://mindfusion.eu/Forum/YaBB.pl?num=1382622248), you should have access to it from your account page at http://clientsarea.eu/.
