Normal Topic Calendat Sub Header (Read 2195 times)
ColinA
Calendat Sub Header
Oct 23rd, 2013 at 10:00am
Hi
Can you set  set colour of   the  sub headers on the  calendar when adding a new contact to the schedule to different colours
cheers
Re: Calendat Sub Header
Reply #1 - Oct 23rd, 2013 at 10:40am
If you want to color the headers of the columns in a grouped Timetable view, you need to rely on custom drawing. Set Calendar.CustomDraw to CustomDrawElements.TimetableColumnHeader, handle the Calendar.Draw event and perform the drawing in the event handler, for example:
void calendar_Draw(object sender, DrawEventArgs e)
	if (e.Element == CustomDrawElements.TimetableColumnHeader)
		e.Graphics.DrawRectangle(Pens.Red, e.Bounds);
Keep in mind that the custom drawing is performed after the element's default appearance has already been rendered. Therefore, if you fill the area with solid color, you may need to manually repaint the header text.
