Normal Topic Node Effects on Custom Nodes (Read 4572 times)
Waterfiets
Oct 29th, 2013 at 10:56am
Hi there,
I saw this example http://www.mindfusion.eu/onlinehelp/wpfdiagram/index.htm on your website and wanted to try it out. But i think it's not working because we're using custom nodes. Could you give any tips?
Thanks in advance.
Greets,
Sander
Re: Node Effects on Custom Nodes
Reply #1 - Oct 29th, 2013 at 11:42am
The built-in effects cannot be applied to custom nodes, because the control cannot know to which parts of your custom-drawn WPF visual tree they should be applied. These effects mostly add some radial gradients to the nodes' background, so you should be able to draw something similar in the Draw override using a RadialGradientBrush at the locations you want 'reflections' to appear.
Waterfiets
Reply #2 - Oct 29th, 2013 at 12:14pm
Ok thanks! I was using that at the moment, but i didn't know it could look that fancy using the RadialGradientBrush.
Greets,
Sander
Waterfiets
Reply #3 - Oct 29th, 2013 at 12:48pm
Btw, with which property could i give some depth to my custom nodes and maybe some shades?
Reply #4 - Oct 29th, 2013 at 2:41pm
You could set the node's UIElement.Effect property to a DropShadowEffect instance. That's not one of ours but provided by WPF.
Waterfiets
Reply #5 - Oct 29th, 2013 at 3:38pm
Ah, that looks nice. Are there any other nice effects that could make the nodes look a bit more fancy?
Thanks in advance.
Greets,
Sander Leune
Reply #6 - Oct 29th, 2013 at 5:01pm
Check the other effect classes in the Inheritance Hierarchy section here, I'm not sure what they do:
http://msdn.microsoft.com/en-us/library/system.windows.media.effects.effect.aspx
You could also change the UIElement.Opacity property to make your nodes translucent.
Waterfiets
Reply #7 - Oct 30th, 2013 at 8:24am
Thanks, this has some nice features, but i'm surprised that its quite concise. In other words, the visual options that wpf offers isn't that extensive.
Greets,
Sander
