Normal Topic Background color of a custom node (Read 3490 times)
Rennie
Oct 30th, 2013 at 8:55am
With the WinForms version my custom nodes don't have any background color. All that is visible for the nodes are the things that I render in the Draw() or DrawLocal() method. Can't remember now if I had to do any setup of anything to make it work like that.
On Android the bounds of my custom nodes are shown as a rectangle, a bit darker than the background for the whole diagram. What should I do to avoid that?
Re: Background color of a custom node
Reply #1 - Oct 30th, 2013 at 11:35am
That could be the node's shadow, try adding a no-op drawShadow override:
@Override
protected void drawShadowLocal(Canvas g, RenderOptions options)
Rennie
Reply #2 - Nov 2nd, 2013 at 2:31am
Yes, that fixed the problem. Thanks.
