Normal Topic Shapenode with custom shape? (Read 1799 times)
Dominik Egger
Oct 31st, 2013 at 1:15pm
I am currently trying to create a shapenode where the outline is defined by a Shape (Mindfusion.Diagramming.Shape). The coordinates of the shape are in the region of 0 - 1000.
However, if I assign the shape to the shapenode it gets drawn outside of the rectangle (see attachment).
My c# code is:
 List<ElementTemplate> outlines = new List<ElementTemplate>();
        outlines.Add(new LineTemplate(points[0].X , points[0].Y , points[1].X , points[1].Y ));
        for (int i = 1; i < points.Count - 1; i++)
          outlines.Add(new LineTemplate(points[i].X , points[i].Y , points[i + 1].X , points[i + 1].Y ));
        Shape shape = new Shape(outlines.ToArray(), System.Drawing.Drawing2D.FillMode.Winding, "outline");
        ShapeNode shapeNode = diagram2.Factory.CreateShapeNode(0,0,100,100,shape);
Re: Shapenode with cusom shape?
Reply #1 - Oct 31st, 2013 at 1:17pm
Shape coordinates specify percents of the node's width and height, you should set them to values in the 0-100 range.
Dominik Egger
Re: Shapenode with custom shape?
Reply #2 - Oct 31st, 2013 at 1:18pm
oh,
Should have reat the documentation more thorougly...
thanks  Smiley
