Normal Topic diagramlink style at the linkhead (Read 1589 times)
esri_test
Nov 1st, 2013 at 7:17pm
Hi Stoyo,
I set the diagramLink brush and diagram stroke locally with a default style. The brush and stroke will overwrite the default value with one exception on the diagramLink head boundary. Please found the attached image. The brush and stroke are all in orange, but the boundary of the linkhead triangle is in black. Is there another attribute to set on that?
Re: diagramlink style at the linkhead
Reply #1 - Nov 1st, 2013 at 7:47pm
Links have a separate HeadStroke property for stroking the arrowhead shapes. Set it to the same value as Stroke, or to the Transparent brush.
