Normal Topic Winforms .NET Planner exception when mouse move... (Read 3974 times)
Gulfraz Khan
Nov 11th, 2013 at 10:45am
I am getting an exception in my application when I move mouse from contacts list section to schedules/time plan section.
Following is the exception:
System.ArgumentOutOfRangeException was unhandled.
Message="The added or subtracted value results in an un-representable DateTime.
Parameter name: value"
Attachment contains the details of the exception.
Application uses latest version of MindFusion Planner control in visual studio 2010 and the target framework is 2.0.
Re: Winforms .NET Planner exception when mouse move...
Reply #1 - Nov 11th, 2013 at 2:04pm
Can you provide the additional information you mentioned in your initial post? Also, what do you mean by "contacts list section", are you referring to a portion of the view? If this is the case, can you post your view settings?
Gulfraz Khan
Reply #2 - Nov 13th, 2013 at 4:37am
Hi
I have a calendar view (Please see attachment in my initial post). On the extreme left, it contains the list of employee names for whom I want to set appointments. In the runtime, when I move my mouse from the cell (containing the name of an employee) to its adjacent cell (timeline area). It throws the specified exception.
Kind Regards,
Gulfraz
Reply #3 - Nov 13th, 2013 at 7:31am
I am not able to find an attachment to your initial post. However, I assume you are using the Resource view and from your description it sounds like a bug we have fixed some time ago. Can you check if the problem persists in the most recent version of the control:
https://mindfusion.eu/_temp/MindFusion.Scheduling.5.4.5.trial.zip
