Normal Topic Save position of the nodes of DiagramView (Read 1650 times)
ddol
Nov 11th, 2013 at 11:25am
I have a DiagramView with BackgroundImage, and on this image/document the user draws transparent rectangles to locate areas of the document.
diagramView.Behavior = Behavior.DrawShapes;
diagram.DefaultShape = Shapes.Rectangle;
diagramView.Diagram.ShapeNodeStyle.Brush = new MindFusion.Drawing.SolidBrush(Color.Transparent);
diagramView.Diagram.DiagramStyle.ShadowBrush = new MindFusion.Drawing.SolidBrush(Color.Transparent);
diagram.BackgroundImage = Image.FromFile("e:\\temp\\invoice.tiff");
diagram.Invalidate();
It is possible save only the position of nodes (rectangles) (without image) but display image + nodes?? (diagramView.SaveToFile, diagramView.SaveToStream????)
Thanks in advance
Re: Save position of the nodes of DiagramView
Reply #1 - Nov 11th, 2013 at 11:53am
You could temporarily set BackgroundImage to null before calling a SaveTo* method to avoid saving it. Alternatively, do not set that property at all, but call e.Graphics.DrawImage from a DrawBackground event handler to draw the background.
