Normal Topic Release vs. Licensed (Read 1233 times)
j poz
Nov 12th, 2013 at 7:38pm
What is the difference between the Release configuration and the Licensed configuration?
Re: Release vs. Licensed
Reply #1 - Nov 13th, 2013 at 7:13am
Build with Licensed config. Release appears when we run some scripts that merge the solution from several others, we'll see if we can stop it from appearing.
