Normal Topic GetHeaderFromPoint in Javascript (Read 1594 times)
jlj30
Nov 12th, 2013 at 10:09pm
Thanks to some code that you provided more that a year ago, I have been able to do the following:
protected void OnNodeClicked(object sender, NodeEventArgs e)
RectangleF bounds = RectangleF.Empty;
            Header header = DiagramView1.Diagram.LaneGrid.GetHeaderFromPoint(e.MousePosition, ref bounds);
I now need to accomplish the same thing in Javascript.
However, if I try the following, the alert does not fire.
Any suggestions?
Code (Javascript)
function onClientNodeClicked(sender, args)
var mousePos = args.getMousePosition();
                        alert('mousePos = ' + mousePos);
Here's the DiagramView declaration:
Code (HTML)
<ndiag:DiagramView ID="DiagramView1" runat="server" ClientSideMode="ImageMap" Behavior="DoNothing"
                                        Height="100%" NodeClickedScript="onClientNodeClicked" OnCreatingAreaElement="DiagramView1_OnCreatingAreaElement"
                                        LinkClickedScript="onClientLinkClicked" EnableViewState="true">
                                    </ndiag:DiagramView>
Thanks in advance for any assistance.
Jim
Re: GetHeaderFromPoint in Javascript
Reply #1 - Nov 13th, 2013 at 7:54am
Unfortunately you can't do that much on client side in ImageMap mode. You could get the mouse position by adding your own event listeners to the node's AREA element, but then the LaneGrid and Header objects are not accessible either on the client side.
