Normal Topic Nodes are placed on top of each other when using v6.0.2 of MindFusion.Diagramming.FlowLayout (Read 1366 times)
farshid
Nov 19th, 2013 at 3:13pm
Hi
I have recently updated the mindfusion dll to use the latest version and now my graphs are broken. I use to be able to render the graph using FlowLayout however now it renders all node on top of each other. Below is my code:
dim layout = New FlowLayout
layout.HorizontalGroupOffset = 35
layout.VerticalGroupOffset = 35
layout.NodeDistance = 30
layout.Margins = SizeF.Empty
layout.AutoRoute = True
layout.RecreateGraph = True
Dim rules As FlowLayoutRules = layout.LayoutRules
rules.PreferredRules = PreferredRules.ConnectorRules
rules.ConnectorRules.DownOriented = New String() {"ControlFlow", "Down"}
rules.ConnectorRules.RightOriented = "False"
rules.ConnectorRules.HorizontalBendOrientation = False
layout.Arrange(diagram)
diagram.ResizeToFitItems(5)
This is very urgent so I would very much appreciate your help.
Kind regards,
Farshid
Re: Nodes are placed on top of each other when using v6.0.2 of MindFusion.Diagramming.FlowLayout
Reply #1 - Nov 19th, 2013 at 6:13pm
Please attach the diagram saved as xml file. What version of the control were you using last?
