Normal Topic Problem with Scrollbars in DiagramView (Read 1532 times)
ddol
Nov 19th, 2013 at 3:31pm
I have a Window Form with a DiagramView.
The scrollbars property is: diagramView.ShowScrollbars = true, but don't display scrollbars...
What another property I should be set? What's the problem?
Designer:
    'ddPagina: DiagramView
    Me.ddPagina.AutoScroll = False 'Me.ddPagina.AutoScroll = True
    Me.ddPagina.BackColor = System.Drawing.SystemColors.Window
    Me.ddPagina.Behavior = MindFusion.Diagramming.Behavior.DoNothing
    Me.ddPagina.Diagram = Me.diagram
    Me.ddPagina.Dock = System.Windows.Forms.DockStyle.Fill
    Me.ddPagina.Location = New System.Drawing.Point(0, 0)
    Me.ddPagina.Name = "ddPagina"
    Me.ddPagina.Size = New System.Drawing.Size(540, 573)
    Me.ddPagina.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighSpeed
    Me.ddPagina.TabIndex = 0
    Me.ddPagina.Text = "DiagramView1"
    'diagram: Diagram
    Me.diagram.AlignToGrid = False
    Me.diagram.AutoAlignDistance = 0.0!
    Me.diagram.BackBrush = New MindFusion.Drawing.SolidBrush("#FFF5F5F5")
    Me.diagram.DefaultShape = MindFusion.Diagramming.Shape.FromId("Rectangle")
    Me.diagram.MeasureUnit = MindFusion.Diagramming.MeasureUnit.Pixel
    Me.diagram.RoutingOptions.GridSize = 16.0!
    Me.diagram.RoutingOptions.NodeVicinitySize = 48.0!
    Me.diagram.SelectAfterCreate = False
    Me.diagram.ShadowsStyle = MindFusion.Diagramming.ShadowsStyle.None
Thanks in advanced
Re: Problem with Scrollbars in DiagramView
Reply #1 - Nov 19th, 2013 at 6:22pm
Set larger diagram.Bounds, or call diagram.ResizeToFitItems if there are items outside the view you cannot scroll to. If you want scrollbars to be visible even if the view is larger than the diagram, you will have to enable view.HScrollBar.Visible and view.VScrollBar.Visible after each change of  diagram size or zoom factor.
