Normal Topic Changing size of Expand/Collapse buttons (Read 2170 times)
David Long
Nov 19th, 2013 at 4:41pm
Is it possible to change the size of the expand/collapse buttons used in a hierarchical flowchart so they are easier to use in a touch screen environment?
I'm using flowchart .NET 5.3.5.
DavidL
Re: Changing size of Expand/Collapse buttons
Reply #1 - Nov 19th, 2013 at 6:29pm
It's not possible at this time. You could toggle GetNearestNode().Expanded from Diagram.Clicked event handler to give users some slack if they miss the icon.
David Long
Reply #2 - Nov 20th, 2013 at 10:46am
Thanks, that sounds like a good idea.  I don't have that function in my version of the software (5.3.5), so I may have to upgrade to the latest version or think of another solution.
Possibly, click on a box once to select it and click again to expand it.
DavidL
Reply #3 - Nov 20th, 2013 at 10:51am
Check if there is GetNodeAt(point, threshold) method overload in 5.3.5, it should do the job too.
