Normal Topic Resize node size based on size of text (Read 1343 times)
newbieDraw
Nov 21st, 2013 at 4:43pm
Stoyo,
I have a custom node in which I have marked out 25% area for an icon and 75% for text. Nodes are all of the same (fixed) size when they are created. Sometimes the text is too big for the allocated area. Is there a way to automatically resize the node if the text does not fit?
Re: Resize node size based on size of text
Reply #1 - Nov 21st, 2013 at 7:07pm
Call Diagram.CreateMeasureGraphics() from your text property setter and then use various Graphics.MeasureString() overloads to find the text size.
