Normal Topic FlowChart CreateImage paints a shadow on links (Read 1222 times)
Gabriel
Nov 27th, 2013 at 9:36am
I'm trying to use the createImage method on a flowchart, but although the links on the diagram doesn't have any shadow, the created image shows all links with a grey link alongside it as it is a shadow.
How can I deactivate this to just get an image with links without shadows?
Thank you in advance
Re: FlowChart CreateImage paints a shadow on links
Reply #1 - Nov 27th, 2013 at 10:02am
Have you set ShadowsStyle = None, or assigned transparent brushes to the ShadowBrush property of links? I can't see link shadows in exported images either way. If you are looking at the image at high zoom level, note that you might be seeing gray pixels between link lines and the background because of GDI+ anti-aliasing.
