Normal Topic Calendar time table view (Read 2835 times)
Gajee
Nov 27th, 2013 at 10:06am
i'm new for mind fusion calendar control. currently i'm using trial version calendar control. i have few question in the time table view.
1. can i use button and label control in the time table view each appointment?
2. how to use the styled text in the appointment header text?
3. how to appointment header text specific word with background color?
3. how to place the my own icons in the end of each appointment header text?
Re: Calendar time table view
Reply #1 - Nov 27th, 2013 at 10:41am
You cannot display controls inside appointments. You can simulate button and label by using custom drawing or custom item viewer and handling the ItemClick event of the Calendar. If you need these controls to be visible only when the item is in-place edited, you can use a custom item editor.
This is not possible. Currently styled texts can be used only in the item's description.
This is not possible out-of-the-box. You have to rely on custom drawing and perform the necessary painting manually.
If you need to display a single icon, you can assign it to the Image property of the item's Style. If you need to display more than one icon, you need to use custom drawing. You can check the AdvancedItemDrawing sample to see how you can do this and more.
Gajee
Reply #2 - Nov 27th, 2013 at 3:19pm
hi,
thanks for your quick response
