Normal Topic Moving/selecting custom shapes created by CreatePathDelegate (Read 1384 times)
Arash
Dec 6th, 2013 at 12:33am
I have created Node on diagram using standard Shapes and they work fine.
When I create a custom shape using delegate CreatePathDelegate it cannot be selected. Should I change Handler or something for these custom shapes?
As you can see in the picture the yellow shape is create by Shapes.Save and works fine.
However the blue shape is create by CreatePathDelegate and behaviors differently. Although the share the same method to be created as a Node and have the same properties configuration.
Here is my method to create shape:
public virtual GraphicsPath CreateNodePath(RectangleF nodeBounds)
PointF[] shapePoints = new PointF[5];
shapePoints[0] = new PointF(nodeBounds.Left, nodeBounds.Top);
shapePoints[1] = new PointF(nodeBounds.Right, nodeBounds.Top);
shapePoints[2] = new PointF(nodeBounds.Right, nodeBounds.Bottom);
shapePoints[3] = new PointF(nodeBounds.Left, nodeBounds.Top + nodeBounds.Height);
shapePoints[4] = shapePoints[0];
var g = new GraphicsPath();
// g.AddRectangle(nodeBounds);
g.AddLines(shapePoints);
g.CloseAllFigures();
return g;
As you can see I have tried g.AddRectangle(nodeBounds); and still no luck!
Arash
Re: Moving/selecting custom shapes created by CreatePathDelegate
Reply #1 - Dec 6th, 2013 at 7:06am
The path returned by that delegate is rendered by nodes' DrawLocal method and path coordinates should be specified in the node's local coordinate system, starting from [0,0]. This should work:
    shapePoints[0] = new PointF(0, 0);
    shapePoints[1] = new PointF(nodeBounds.Width, 0);
    shapePoints[2] = new PointF(nodeBounds.Width, nodeBounds.Height);
    shapePoints[3] = new PointF(0, nodeBounds.Height);
    return g;
