Normal Topic Right-click on a set of selected nodes changes the selection to one node (Read 1642 times)
newbieDraw
Dec 9th, 2013 at 4:11pm
Hi Stoyo,
I ported one of my earlier applications (VS2008, .NET 3.5) to VS2012 .NET 4.0. Now, I am seeing this problem where my selection is reduced to just one node when I right-click on the selection. I have another application using the Mindfusion API and I don't see this issue in that. Do you know what might be causing this?
Re: Right-click on a set of selected nodes changes the selection to one node
Reply #1 - Dec 9th, 2013 at 6:13pm
That seems to happen if you set DiagramView.RightButtonActions = Select;
newbieDraw
Reply #2 - Dec 9th, 2013 at 6:47pm
Thanks.
