Normal Topic Disable re-sizing of shapes (Read 3859 times)
Kiran B
Dec 13th, 2013 at 9:07am
Is there any way to avoid re-sizing of a node? But links drawing and movement of nodes should not be disabled.
Kiran B
Re: Disable re-sizing of shapes
Reply #1 - Dec 13th, 2013 at 9:24am
Call node.setEnabledHandles(AdjustmentHandles.Move);
Kiran B
Reply #2 - Dec 16th, 2013 at 10:51am
Hi Stoyan,
We are getting the below error
Uncaught ReferenceError: AdjustmentHandles is not defined
Kiran B
Reply #3 - Dec 16th, 2013 at 10:59am
Add the following line or use fully qualified name:
var AdjustmentHandles = MindFusion.Diagramming.AdjustmentHandles;
