Normal Topic Bent arrow - how do I avoid this (Read 2123 times)
jlj30
Dec 13th, 2013 at 7:50pm
Occasionally, I get results similar to the attached screenshot.
The arrowhead is positioned at a rather odd angle.
The screenshot shows a circular shape, but it also happens with rounded rectangles.
Any suggestions on why this might happen and what I might do to prevent it?
Thanks in advance.
Jim
Re: Bent arrow - how do I avoid this
Reply #1 - Dec 16th, 2013 at 8:18am
Is that collector label an attached node? If it is, auto-routed links will go around it as in the image. You could either move it further to the left to avoid the NodeVicinity* penalty costs applied by the auto-routing function, or set its Obstacle property to false if you don't care about links crossing it.
jlj30
Reply #2 - Dec 16th, 2013 at 4:51pm
Yes "Collector" was an attached node, and did move it further to the left as you suggested.
Worked just fine.
Thanks for the tip.
Jim
