Hot Topic (More than 10 Replies) Contextmenu questions (Read 8813 times)
Waterfiets
Dec 17th, 2013 at 2:01pm
Hi Stoyan,
In our application i'm using an Contextmenu to edit some node values. After a while i wanted to change the look of the contextmenu by changing the color so it would fit the design of our modeler. Well, it did change the color but not of the whole context menu. There seems to be some sort of 'strip' on the left side of the menu which seems to keep the original color.
What i want to do is either remove the part on the left, which seems reserved for icons, or change the color of the 'strip' so it doesn't interfere with the look.
Could you give any information on why this is happening and how i can fix it?
Thanks in advance.
Greets,
Sander
Re: Contextmenu questions
Reply #1 - Dec 17th, 2013 at 3:09pm
It seems you'll have to modify menu's Xaml template to edit that color:
http://social.msdn.microsoft.com/Forums/vstudio/en-US/23bc2e08-d220-4e21-bd08-4a...
Waterfiets
Reply #2 - Dec 17th, 2013 at 3:11pm
Hi Stoyan,
Ah, you probably had better search criteria then i had. Thanks for the info, atleast i know its possible:)
Greets,
Sander
Waterfiets
Reply #3 - Dec 19th, 2013 at 11:19am
Hi Stoyan,
Thanks to your suggestion i was able to make a template for my custom Contextmenu in a WPF based testproject and it worked out pretty nice. Now i wanted to apply this to the main project which is a wf project that hosts the Mindfusion wpf project.
The problem i encountered is that once i set the style of my MenuItem to Application.Current.Resources[MenuItemStyle] as Style; Which refers to my xaml in the code below. I get an error. Do you perhaps have any tips on how to solve this?
 <Application x:Class="TSFBRModeler.App"
             xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
             xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
             StartupUri="BRModeler.xaml">
    <Application.Resources>
            <Style TargetType="{x:Type MenuItem}" x:Key="MenuItemStyle">
                <Setter Property="Background" Value="Gray"></Setter>
                <Setter Property="Foreground" Value="White"></Setter>
                <Setter Property="FontSize" Value="13"></Setter>
                <Setter Property="FontFamily" Value="Verdana"></Setter>
                <Setter Property="Margin" Value="-5,0,0,0"></Setter>
                <Style.Triggers>
                    <Trigger Property="IsHighlighted" Value="True">
                        <Setter Property="Background" Value="Black"></Setter>
                        <Setter Property="FontSize" Value="15"></Setter>
                    </Trigger>
                    <Trigger Property="IsEnabled" Value="False">
                        <Setter Property="Foreground" Value="LightGray"></Setter>
                    </Trigger>
                </Style.Triggers>
            </Style>
    </Application.Resources>
</Application>
Greets,
Sander
Reply #4 - Dec 19th, 2013 at 1:57pm
What kind of error are you getting?
Waterfiets
Reply #5 - Dec 20th, 2013 at 7:33am
Well i assume the problem is that WF doesnt have application wide resources, i.e. App.xaml. Which means i cant reach the file which contains the information about the template. Anyhows, i found a workaround, i made the template programmatically instead of using the xaml. Thanks anyway:D
Reply #6 - Dec 20th, 2013 at 8:01am
Well, it works without any errors in my test, with your exact Xaml copied to App.xaml:
if (e.MouseButton == MouseButton.Right)
	var menu = new ContextMenu();
	var item = new MenuItem();
	item.Header = "that's me";
	item.Style = (System.Windows.Style)Application.Current.Resources["MenuItemStyle"];
	menu.Items.Add(item);
	menu.IsOpen = true;
	return;
Waterfiets
Reply #7 - Jan 8th, 2014 at 10:30am
This is the stacktrace of the error i get:
   at TSFBRModeler.TSFBRDiagramNodes.TSFBRContextNodes.BRSetActiveTabNode.Draw(DrawingContext graphics, RenderOptions options) in c:\Users\sleune\trunk_bsr\TSFBRModeler\TSFBRDiagramNodes\TSFBRContextNodes\BRSetActiveTabNode.cs:line 353
   at MindFusion.Diagramming.Wpf.DiagramItem.OnRender(DrawingContext drawingContext)
   at System.Windows.UIElement.Arrange(Rect finalRect)
   at A.A.ArrangeOverride(Size arrangeSize)
   at System.Windows.FrameworkElement.ArrangeCore(Rect finalRect)
   at System.Windows.ContextLayoutManager.UpdateLayout()
   at System.Windows.ContextLayoutManager.UpdateLayoutCallback(Object arg)
   at System.Windows.Media.MediaContext.InvokeOnRenderCallback.DoWork()
   at System.Windows.Media.MediaContext.FireInvokeOnRenderCallbacks()
   at System.Windows.Media.MediaContext.RenderMessageHandlerCore(Object resizedCompositionTarget)
   at System.Windows.Media.MediaContext.RenderMessageHandler(Object resizedCompositionTarget)
Maybe you see something i dont. Cool
Edit:
Line 353 = rightField.Style = (System.Windows.Style)Application.Current.Resources["MenuItemStyle"];
Edit:
Extra info: The TSFBRModeler WPF solution is hosted by the WF Solution TSFBRModelerBootStrap. And the startup type of TSFBRModeler is class library.
Would the startupuri then be different?
Reply #8 - Jan 8th, 2014 at 12:26pm
What kind of exception is thrown there?
Waterfiets
Reply #9 - Jan 8th, 2014 at 1:11pm
It threw an Null Reference exception, i.e. the value of the object was null.
Reply #10 - Jan 8th, 2014 at 1:36pm
And it isn't the rightField variable having a null value?
Waterfiets
Reply #11 - Jan 8th, 2014 at 2:56pm
Nope, the values are hard coded atm.
Reply #12 - Jan 8th, 2014 at 3:16pm
If you add a breakpoint to that Line 353, which one is null when it hits - rightField, Application.Current or Application.Current.Resources?
Waterfiets
Reply #13 - Jan 8th, 2014 at 3:18pm
The value of Application.Current is null.
Reply #14 - Jan 8th, 2014 at 3:25pm
static App()
	Debug.WriteLine(Application.Current);
App()
This test shows Application.Current is null during static initialization, and is already set in the instance constructor App() (i.e. once the base Application constructor has executed). So I suppose your code runs from a static constructor or initializer of some kind, and apparently you won't be able to access resources then. You should still be able to load the style at a later point.
