Normal Topic No click event for custom shape? (Read 1908 times)
Vincent
Dec 19th, 2013 at 2:06pm
Hi Stoyan,
In our operator node (with the left and right slot), we want to catch the event when an user clicks on the slot. I did this by overriding the method OnMouseLeftButtonUp but this method is never reached in the debugger when I click on a slot.
I temporarily commented the override of ContainsPoint out but this doesn't help either.
Do you have an idea? Is it perhaps the override of Draw()?
protected override void OnMouseLeftButtonUp(MouseButtonEventArgs e)
            base.OnMouseLeftButtonUp(e);
            Point mousePosition = e.GetPosition(this);
            Rect detectionArea = new Rect(...);
            if (detectionArea.Contains(mousePosition))
                //Do something
Thanks in advance!
Vincent
Re: No click event for custom shape?
Reply #1 - Dec 19th, 2013 at 4:53pm
Since your node class doesn't contain any child graphic elements in the slot area, WPF won't pass mouse events to a node when you click inside its slot. Try filling the slot area with not-entirely transparent color but one with very small alpha value, and you should start getting events.
Vincent
Reply #2 - Dec 20th, 2013 at 7:56am
Works impeccably, thanks!  Smiley
Greets,
Vincent
