Normal Topic Size of ContainerNode (Read 4225 times)
Kuzya
Dec 23rd, 2013 at 10:47am
Hello  together,
I have a question. With the insertion a DiagrammNode in a ContainerNode the size of ContainerNode changes. Which function reacts to the change? The function NodeModifying () does not react to the change.
Thank you very much.
Kuzya
Re: Size of ContainerNode
Reply #1 - Dec 23rd, 2013 at 11:48am
You can detect the new container size from ContainerChildAdded event handler. You could also disable ContainerNode.AutoShrink to prevent resizing containers to smaller size, but only let them grow. Containers always growing in size is not strictly required anymore - that was necessary in earlier versions when containers could not clip their child nodes' graphics, and dropping a child near the borders would make it stick out of the container. Since we implemented clipping in version 6, now we could also add a property to disable auto-growing when new children are added, if that's what you are trying to achieve.
Kuzya
Reply #2 - Dec 23rd, 2013 at 12:29pm
My exit situation is following
I have a container with a diagramme inside in the container if I one more children element on the left in diagramme add then container his size and the edges to her connections with elements changes lose. The losing happens only graphically. So I need the reaction on the change the size of container.
Reply #3 - Dec 23rd, 2013 at 1:08pm
Sorry, I cannot understand you. If you want to assign your custom bounding rectangle to a container, call container.SetBounds(rect, false, true). To resize a container to fit its contents, call ContainerNode.UpdateBounds().
Reply #4 - Jan 6th, 2014 at 3:01pm
I cannot reproduce that, please let me know what I should change in this project to see it happen:
https://mindfusion.eu/_samples/TestContainers.zip
Kuzya
Reply #5 - Jan 6th, 2014 at 4:06pm
This is my problem.
Kuzya
Reply #6 - Jan 6th, 2014 at 4:09pm
FlowChart. NET demo->; container 4-> the first element (yellow) to the right push the size of container changes and all elements her edges lose.
Reply #7 - Jan 6th, 2014 at 4:46pm
I cannot reproduce that either. What version of the control are you using?
