Normal Topic Get a context menu on shape node (Read 5159 times)
Alok
Dec 25th, 2013 at 5:29am
How to get context menu on a shape node using ASP.NET MVC ?
Re: Get a context menu on shape node
Reply #1 - Dec 26th, 2013 at 11:05am
There's no built-in support for context menus. You could use a third party library to create a menu and then show it from the NodeClickedScript function. You will also need to disable browser's own right click menu.
1. Disable the browser menu by setting the canvas oncontextmenu handler:
$get("diagram").oncontextmenu = function () { return false };
2. Add a NodeClicked event handler, e.g. from server
diagramView.NodeClickedScript("onNodeClicked");
or from client side
var diagram = $find("diagram");
diagram.addEventListener(MindFusion.Diagramming.Events.nodeClicked, onNodeClicked);
3. Create a context menu using this jQuery plugin for example:
http://plugins.jquery.com/contextMenu/
$.contextMenu({
	selector: "#diagram",
	trigger: "none",
	callback: function (key, options)
		if (key == "delete")
			$find("diagram").removeItem(clickedNode);
	items: {
		"delete": { name: "Delete" }
4. Show the menu from NodeClicked handler:
var clickedNode;
function onNodeClicked(sender, args)
	clickedNode = args.getNode();
	if (args.getMouseButton() == 2)
		var clientPt = $find("diagram").docToClient(args.getMousePosition());
		$("#diagram").contextMenu(clientPt);
liza
Reply #2 - Apr 26th, 2019 at 6:19am
I tried the same but getting error $find is not a function. Please can you help me for the same?
AIM
Reply #3 - Apr 26th, 2019 at 6:26am
$find is from MS Ajax mode. Otherwise you can find client side Diagram instance by setting var diagram = MindFusion.Diagramming.Diagram.find('your DiagramView ID');
liza
Reply #4 - Apr 26th, 2019 at 9:11am
It worked. Thanks! Smiley
AIM
