Normal Topic is there any hot key for wrapping text for shape object (Read 1732 times)
chieh
Jan 3rd, 2014 at 8:21am
Hello
I Would like to ask is there any hot key, something like ctrl+c as copy, ctrl+v  as paste, for wrapping text which is describing for shape?
currently we are using latest mindfusion pack in asp.net 4.0 environment.
Many thanks
Re: is there any hot key for wrapping text for shape object
Reply #1 - Jan 3rd, 2014 at 9:01am
Do you mean copying the text from a node into another one? If you enable in-place editing, you will be able to copy or paste inside the text boxes that appear after double click.
