Normal Topic Provide sample code for the demos (at least for the Layered Layout demo) (Read 2801 times)
martink
Jan 4th, 2014 at 5:20am
Can you please provide the source code used for the Diagramming demos for asp.net. It will be really helpful to see what is possible and then to see how it is done. What I need right now is to understand how the Layered Layout demo is implemented as I have a few challenges - e.g. put the text below the image.
Martin
Re: Provide sample code for the demos (at least for the Layered Layout demo)
Reply #1 - Jan 4th, 2014 at 10:10am
You can find sample projects installed with the control, under the ProgramFiles\MindFusion...\VS2010\Samples\ folder. There are also VS2008 and VS2012 versions available, installed if you select the respective options during setup.
Regarding putting text below images, check the IconNodes sample project. It demonstrates how to create custom node types that draw images and labels, with variants for both Canvas and ImageMap front-ends.
In the same location you can also find the LayeredLayout sample project. It implements a text-below-image node using the standard ShapeNode class, where the Image is top-aligned and Text is bottom aligned:
// create the box
ShapeNode node = diagram.Factory.CreateShapeNode(
    rnd.Next(10, 520), rnd.Next(10, 340), 40, 50);
node.Text = diagram.Nodes.Count.ToString();
node.TextFormat.LineAlignment = StringAlignment.Far;
node.HyperLink = "http://mindfusion.eu";
//node.HyperLink = "javascript: void alert('clicked')";
// setup icon
node.Transparent = true;
node.Image = new Bitmap(
    Server.MapPath("Images\\" + rnd.Next(4).ToString() + ".png"));
node.ImageAlign = ImageAlign.TopCenter;
martink
Reply #2 - Jan 10th, 2014 at 10:01am
Hi Stoyo,
Many thanks!
Martin
