Normal Topic Manage multiple lines textstyle (Read 6800 times)
JR
Jan 10th, 2014 at 1:40pm
Firstly have an happy new year.
Here is my question.
I want to manage the multiline textstyle of a box (tsCenterML).
What is the best way to have a line feed where I want (what separator for example) ?
Same question for the JDiagram version.
Regards
Juan
Re: Manage multiple lines textstyle
Reply #1 - Jan 10th, 2014 at 1:57pm
Happy new year! If you are using the control from VB, use the vbCrLf constant:
node.Text = "line 1" + vbCrLf + "line 2"
In C-like languages and for JDiagram use the \r\n escape sequence:
node.setText("line 1\r\nline 2");
JR
Reply #2 - Jan 10th, 2014 at 2:01pm
Does the
Ocx_Flowchart.MeasureString  function count the crlf characters ?
Reply #3 - Jan 10th, 2014 at 2:21pm
FlowChart.MeasureString calls Win32 GetTextExtentPoint32 function which does not seem to count multiple lines. Instead, you could use a temporary node to measure text by calling its FitSizeToText method.
JR
Reply #4 - Jan 10th, 2014 at 2:58pm
