Normal Topic Container size increases when it reaches server (Read 2521 times)
Kiran B
Jan 15th, 2014 at 9:46am
I am facing an issue in which the container size is increasing when it has child container nodes in it.
The size is increasing when it reaches the server side.
In the json data that is passed to sever i could see the actual size but after the below code if i check the width and height it will be increased.
var diagram=DiagramView.FromJson(diagramAsJson);
For example if i have a parent container with a nested container, the json data has width 63 and height 34. But after serialization the width becomes 72 and height becomes 57
Any way to use the actual width and height while serialization.
Kiran B
Re: Container size increases when it reaches server
Reply #1 - Jan 16th, 2014 at 7:14am
It's a bug. This version should fix it:
https://mindfusion.eu/_beta/mvcdiag17.zip
