Normal Topic Switching from Trial to Paid (Read 1702 times)
IGenBen
Jan 21st, 2014 at 8:36pm
We started doing development using the trial version of Diagramming for WinForms but when we switched out the dlls for the paid version it stopped creating the objects. Is this a licensing problem? Is there an easy way to change the licenses.licx file to have the correct key?
Re: Switching from Trial to Paid
Reply #1 - Jan 21st, 2014 at 8:56pm
In licenses.licx, set PublicKeyToken=null at the end of the diagram line. That should make it work with any version of the assemblies. If you still get compilation problems, make sure the "use specific version" property is disabled for all mindfusion.* assembly references in Solution Explorer.
IGenBen
Reply #2 - Jan 21st, 2014 at 8:58pm
Thanks, I'll give that a try!
