Normal Topic Arrange links function (Read 1510 times)
Raizi
Jan 24th, 2014 at 1:29pm
I have a problem when using the MindFusion.Diagramming.Diagram,
when I have 2 links (or more) from table A to table B,
they automatically start at the same point at the Origin table and end at the same point at the destination table.
is there is a function that automatically arrange the links to not stop on each other.
Re: Arrange links function
Reply #1 - Jan 24th, 2014 at 3:18pm
If you are getting such centered links after applying a layout class, try running this code after calling layout.Arrange:
var links = new DiagramLinkCollection();
foreach (var link in diagram.Links)
	if (Math.Abs(link.StartPoint.X - link.Origin.GetCenter().X) < 1)
		link.ReassignAnchorPoints();
		links.Add(link);
diagram.LinkRouter.RouteLinks(links);
