Normal Topic Not able to select the Node below a link (Read 6531 times)
Kiran B
Jan 29th, 2014 at 2:10pm
We are having one issue with link shape.
We are having a node of type MindFusion.Drawing.Rect,  with Width=12 and Height=6 , and when we are having a link passing through the middle of that shape, we are not able to select that node.
I have set the shadowOffsetX and Y to zero. Still not fixed.
Any workaround for this?
Kiran B
Re: Not able to select the Node below a link
Reply #1 - Jan 29th, 2014 at 7:09pm
Try setting Diagram.LinkHitDistance to a small value, e.g. try with 1.
Kiran B
Reply #2 - Jan 30th, 2014 at 6:56am
Hi Stoyan,
Its not fixing the issue.
Also i don't see the LinkHitDistance in client side object only server side has this property.
The real issue is the node is showing the anchor point while mouse over the node, but when clicks the selection happens for the link.
Kiran B
Reply #3 - Jan 30th, 2014 at 5:18pm
There is Diagram.setLinkHitDistance method in the JavaScript API. Setting a small value means you will need to click more precisely near a link to consider that a hit on the link, and that should let you select the node by clicking near its borders, but not within the specified distance from the link. Displaying anchor points is not an indication that clicking there will select the node, it only shows where a new link would snap if you start drawing a link from that node.
Kiran B
Reply #4 - Jan 31st, 2014 at 10:17am
Hi Stoyan,
I don't see that property in the Diagram in js side.
I am using version 1.6.
Kiran B
Reply #5 - Jan 31st, 2014 at 10:27am
I can see it listed in the online help here, which we haven't updated to 1.7 yet, and its help topic should have been imported from the source code:
http://www.mindfusion.eu/onlinehelp/mvcdiagram/index.htm?M_MindFusion_Diagrammin...
Are you trying to call it and getting an error message? Note that's a member of the Diagram class, and not of DiagramLink.
Kiran B
Reply #6 - Apr 15th, 2014 at 7:41am
Hi Stoyan,
I am using like below
$find("diagramControl").setLinkHitDistance(1);
but i get the below error
TypeError: undefined is not a function
Kiran B
Reply #7 - Apr 15th, 2014 at 9:41am
That can be related to either $find or setLinkHitDistance. If the canvas loads correctly and other functions work, it's probably the latter. Make sure you have copied latest diagramming.js to your project, and clear the browser cache in case it keeps an older version of the script.
Kiran B
Reply #8 - Apr 15th, 2014 at 2:16pm
Hi Stoyan,
So do i need to update the version to fix this issue?
I am using version 1.6 now.
Kiran B
Reply #9 - Apr 16th, 2014 at 9:27am
setLinkHitDistance exists in version 1.6 from what I can see. Check if you aren't using a script file from an older release. The diagramming.js I get with v1.6 installation has ‎November ‎08, ‎2013 creation date.
