Normal Topic Diagramming for ASP.NET MVC, V1.7 (Read 3468 times)
Jan 30th, 2014 at 5:05pm
We have released version 1.7 of MindFusion.Diagramming for ASP.NET MVC. It contains the following new features:
Import Visio .vsdx files
The Visio2013Importer class can import .vsdx files, created by Visio 2013. In order to use it, you must add a reference to the MindFusion.Diagramming.Import.Visio.dll assembly. Various overloads of the Import method can be used to import the file into a DiagramDocument whose pages correspond to the Visio drawing pages, or into a single Diagram whose content is merged from all imported pages. Visio2013Importer supports the basic flowchart and data flow Visio stencils. For each node shape from the .vsdx file, the importer creates a ShapeNode object whose Shape, Text, Brush and Pen properties are set to values corresponding to the imported Visio shape. For each connector shape, the importer creates a DiagramLink object whose Origin and Destination are set to the corresponding imported nodes, and whose ControlPoints reflect the geometry of the connector.
Adjustment handle styles
Appearance of nodes' adjustment handles can be customized by setting the HandlesStyle property. Supported styles include round and square handles, dashed and hatched frames, and some combinations. Apart from appearance, the handles style also controls what part of a node can be dragged to move or resize it. It is also possible to render custom handles by handling the drawAdjustmentHandles event, and implement custom hit-testing by handling the hitTestAdjustmentHandles event.
Dynamic links
A dynamic link automatically orients its end segments so that they point to the target nodes' centers while the link's nodes are dragged around. If a node's AnchorPattern is set, link ends will align to the closest anchor point instead. Positions of the link's end points are also updated when the next-to-last control points are being modified. To enable this, set the Dynamic property to true.
ContainerNode enhancements
~ Apply layout algorithms to content of a ContainerNode by calling its arrange method.
~ Selectively prevent adding or removing child nodes to/from a container by handling the containerChildAdding and containerChildRemoving events.
~ The Dirty flag is automatically set when a serializable property of an item or the diagram has been modified. It lets you determine where there are any changes that need to be saved.
~ The AdjustmentHandlesSize property specifies the size of adjustment handles.
~ The ShowDisabledHandles property controls whether disabled adjustment handles are draw on screen.
~ Several new predefined shapes available in the Shapes class - RightTriangle, Decagon, Trapezoid, Star4Pointed, Star5Pointed, Star6Pointed, Star7Pointed, Star16Pointed, Star24Pointed, Star32Pointed, Donut and Plaque.
https://www.mindfusion.eu/MvcDiagramTrial.zip
