Normal Topic Diagram width issue (Read 3253 times)
jlj30
Diagram width issue
Feb 5th, 2014 at 10:14pm
I have employed several techniques that you have provided over the past year and they have all been very helpful.
One such method that I have adapted for my use seems to be causing a problem.
Have a look at the attached screenshots.
The only difference between the 2 diagrams is that the 2nd one (BAD) has links to some nodes in a second swim lane.
Why this would cause the overall diagram to be wider is a mystery to me.  I've been looking at this for too long.  It's time to get your help Smiley
Here's the code that attempts to align the nodes in the 2nd swim lane with their parent in the 1st lane.
It appears to do just what I want (thanks for that), except with the undesirable increase in the diagram width.
Code (C++)
protected void AlignNodeTo(DiagramNode node, DiagramNode relatedNode, Diagram diagram)
		// Code provided by Mindfusion (Stoyan) on 05Jul2013 (with some minor modifications)
		// It ensures that IP and Data shapes are aligned under their parent task
        node.Move(relatedNode.Bounds.X + ((relatedNode.Bounds.Width - node.Bounds.Width) / 2), node.Bounds.Y);
		// find all nodes in the same lane as the aligned one
		var nodesInLane = new List<DiagramNode>();
		foreach (DiagramNode n in diagram.Nodes)
			if (n.LayoutTraits[SwimlaneLayoutTraits.Lane] != null)
					if (n.LayoutTraits[SwimlaneLayoutTraits.Lane].Equals(node.LayoutTraits[SwimlaneLayoutTraits.Lane]))
						nodesInLane.Add(n);
		// if a node intersects the aligned one, move it to the right of it
        foreach (DiagramNode n in nodesInLane)
            if (n != node && n.Intersects(node))
                n.Move(node.Bounds.Right + 5, n.Bounds.Y);
        // Sort the nodes based on their X (left) coordinate
        nodesInLane.Sort((n1, n2) =>
			n1.Bounds.X.CompareTo(n2.Bounds.X));
		// shift remaining nodes to the right to remove overlaps
		for (int i = 1; i < nodesInLane.Count; i++)
			var n1 = nodesInLane[i - 1];
			var n2 = nodesInLane[i];
			if (n2.Bounds.Left <= n1.Bounds.Right)
				n2.Move(n1.Bounds.Right + 5, n2.Bounds.Y);
Here's a bit more code that puts the above in perspective.
The above method is called from alignShapesWithTasks which just loops thru all nodes on the diagram that have one of the shapes in the 2nd swim lane linked to it.
Header colHeader = grid.FindColumn(colTitle);
		if (colHeader.Width < 225)  // Ensure a minimum width
			colHeader.Width = 225;
		// The following code will try to ensure that Data, IP and Annotation shapes are positioned directly below the task to which they are related
        alignShapesWithTasks(diagram);
        System.Diagnostics.Debug.WriteLine("---> diagram.GetContentBounds after alignShapesWithTasks = " + diagram.GetContentBounds(false, false));
		SortRoutedLinksTaskRight(diagram); // helps to reduce overlapping connectors coming out of the right side of a task
		SortRoutedLinksTaskLeft(diagram); // helps to reduce overlapping connectors coming into the left side of a task ** New code from MF - 29Dec2013 **
        SortRoutedLinksTaskBottom(diagram);
        diagram.RouteAllLinks();  // Moved after the above link sorting functions - 27Dec2013
        RectangleF columnHeaderBounds = diagram.LaneGrid.GetColumnHeaderBounds();
        RectangleF rowHeaderBounds = diagram.LaneGrid.GetRowHeaderBounds();
        RectangleF laneGridBounds = RectangleF.Union(columnHeaderBounds, rowHeaderBounds);
        RectangleF itemsBounds = diagram.GetContentBounds(false, false);
        diagram.Bounds = RectangleF.Union(itemsBounds, laneGridBounds);
        diagram.Bounds = new RectangleF(0F, 0F, diagram.Bounds.Width + 2F, diagram.Bounds.Height + 5F);
		// The following ensures a minimum width diagram
        if (diagram.Bounds.Width < 225)
            diagram.Bounds = new RectangleF(0F, 0F, 225, diagram.Bounds.Height);
Any suggestions?
Jim
Re: Diagram width issue
Reply #1 - Feb 6th, 2014 at 2:41pm
I think the Arrange method fills the entire shown width when distributing nodes on second lane by layout's NodeDistance. It also resizes the grid to fit the nodes, but then you move them back to the left when re-aligning and this creates empty space? Try also setting the grid's ColumnHeaders[0].Width to the maximum right coordinate of all nodes (+ some padding value) to fix that.
jlj30
Reply #2 - Feb 10th, 2014 at 12:42pm
Setting the ColumnHeaders[0].Width did the trick.
Surprisingly, I didn't have to add a "padding value", but I'm not complaining.
Jim
Reply #3 - Feb 10th, 2014 at 1:19pm
Ok, Grid.Columns[0].Width does not include the width of row headers, so I suppose you get their width added to the right side if you assign content rectangle's width to column's Width.
